best cold air kit?
Mark's kit slowed me down too. :rolleyes:
Proably be going to sell mine as I don't think it will work with a GT-47.
Jerrad,
If you're looking for an awesome Cold-air intake kit , look here: www.modelman5.com/tinmancoldairkit.htm .........You can also see our ad in the Buick GSX-tra magazine. Flow tested to outflow any other kit on the market. Perfect "NO CUT" fit for stock cars to those running down into the low 9"s. If you want the ultimate cold air kit, give us a call. There IS a difference.
Blackhawk, we are also making mandrel bent 3 1/2" and 4" MAF pipes to the turbo. They can be set up to be used with a MAF or without. ;)
BLACKHAWK said:
DO U DO THE KITS FOR GN THAT DONT RUN A MAF
Yes, we can. Just email me direct with your needs. mhueffman@snet.net
I believe we are the only ones out there offering chrome plated steel, plain aluminum or powder coated aluminum in black or silver. We also have 3 different size MAF pipes, 3", 3.5" and 4". Not to mention we make a cold air kit for the hot air 84-5 TR's.
