Jul 2, 2002 #1 L lteeone New Member Joined Sep 17, 2001 Messages 70 where is a good place to get a CHRA for a 87 GN turbo? Thanks Scott
Jul 2, 2002 #2 U UNGN Can't Re- Member Joined May 24, 2001 Messages 14,029 Did you try NAPA? I know they have BFH's, but I'm not sure if they have CHRA's.
Jul 2, 2002 #3 John Larkin Sublime Master of Turbology Joined May 25, 2001 Messages 5,013 Hehe. What the heck is a CHRA?
Jul 2, 2002 #4 S Steve Wood Active Member Joined Jul 18, 2001 Messages 2,338 Christian Hot Rod Assistant?
Jul 2, 2002 #5 b4black Well-Known Member Joined May 24, 2001 Messages 3,775 Center Housing Rotating Assembly You know, what's left of a turbocharger when you pull the turbine and compressor housings off (you do know what they are, right ) AKA center section. ANY turbo vendor should be able to handle a stock CHRA. Or rebuild it yourself.
