Details of the run:
60' - 1.551
330' - 4.565
1/8 - 7.105
MPH - 95.96
1000' - 9.332
1/4 - 11.204
MPH - 119.45
Best 1/4 MPH to date:120.17
Best 1/8 MPH to date:98.65
My converted 1989 GTA
EMPTY WEIGHT:3300?(3550 w/driver)
BLOCK:stock
HEADS: ported stock tta
TRANSMISSION:TH400
TORQUE CONVERTER
I Vigilante non lockup
DIFFERENTIAL:12 bolt 3.42 gears
INTERCOOLER:CAS V2
THROTTLE BODY:Accufab 65mm
RJC POWER PLATE:yes w/precision plenum
INJECTORS:83#
THERMOSTAT:160
TURBOCHARGER:TE64-1
VALVE SPRINGS:K-Motion K750
MAF:stock
DOWN PIPE:Terry Houston
EXHAUST:ATR
FUEL PUMP:Aeromotive A1000
FUEL PRESSURE REGULATOR:Accufab
FUEL PRESSURE:47psi
ALCHOHOL INJECTION:no
PROPAIN INJECTION:no
NITROUS:no
AIR FILTER AND AIR INTAKE:ATR stainless MAF pipe and 9" K&N
TIRE DESIGN, SIZE & AIR PRESSURE:26x11.5x16 ET Streets @ 15psi hot
AIR BAG(s):yes 25psi right/5psi left
SCAN TOOL:Scanmaster and Directscan
FUEL:Sunoco Ultra 93 (no more 94 in NY
CHIP:Eric Marshall (TurboTweak)
CHIP TIMING:19*
KNOCK RETARD:0*
OXYGEN SENSOR VOLTAGE:.760
EXHAUST GAS TEMPERATURE:n/a
TRACK ELEVATION:close to sea level(E-Town,NJ)
TEMPERATURE:63*
PEAK BOOST:19psi(spikes to 20psi at launch and shifts)
BOOST AT LAUNCH:15psi
MILES ON THE CAR/ENGINE:40,000/15,000 approxamate
I hope to get back out with new tires(27x10.5x16 ET Streets)and see how the revised chips work out. I hope that if conditions are right I can get a 10.9x out of it on pumpgas.
Steve
60' - 1.551
330' - 4.565
1/8 - 7.105
MPH - 95.96
1000' - 9.332
1/4 - 11.204
MPH - 119.45
BLOCK:stock
TRANSMISSION:TH400
TORQUE CONVERTER
INTERCOOLER:CAS V2
INJECTORS:83#
THERMOSTAT:160
TURBOCHARGER:TE64-1
MAF:stock
EXHAUST:ATR
FUEL PRESSURE:47psi
NITROUS:no
CHIP TIMING:19*
KNOCK RETARD:0*
TEMPERATURE:63*
Steve
