nickygn23
- Apr 10, 2011
SignUp Now!Just a quick 87. Our rear sway bar the the same diameter as the UMI rear sway bar. If its the same diameter would it work better? I mean I do have all UMI rear suspension parts, would be cool to match it all.Got a UMI on mine with UMI lowers. Will do the uppers one day.
3034 - 1978-1988 GM G-Body 1" Solid Rear Sway Bar for Improved Handling
Improve handling with the 3034 - 1978-1988 GM G-Body Sway Bar, Rear, Solid, 1". Reduce body roll, increase cornering capabilities, and maintain vehicle levelwww.umiperformance.com
To be honest I don’t know. I feel at least emotionally that in certain circumstances aftermarket can be better. Is UMI the case? Not sure but I like their quality parts. Have their shock tower brace as well.Just a quick 87. Our rear sway bar the the same diameter as the UMI rear sway bar. If its the same diameter would it work better? I mean I do have all UMI rear suspension parts, would be cool to match it all.
The packaging, instructions & fasteners are top notch.I was recommended the HR parts and stuff super sway bar. I just installed it today. It wasn't bad. The packing and directions were great. Not just stuff in a bag.... everything was separated and marked. Instructions very thorough. Still have some questions on how to adjust it. But it might need the engine/trans/driveshaft in to adjust properly. Not sure on that.
Just installed an OLD 1.5" solid rsb, attached to hotchkis solid rear lca. Anyone run one?
If your going for handling why not use the stock away bar?Hello all. I tried and old school ATR rear bar. Didn't 100% like the fitment. Any other ideas that work for you guys. ...Oh not looking for drag bars. Going for handling.
