.. I bet one doughnut its a Red Armstrong
Man i'm good
Problem is ... is the injector constant programmed into the chip for 009's. Why dont you look up the info for Red Armstrong and give him a call. He may be able to tell you based on the numbers the chip has what it is exactly. its not a bad chip fwiw..
If the chip is for 009's.. then you have to look elsewhere for the problem. Also the injectors have numbers on them, you can search those numbers and verify theyre 009's aka 42.5lb.
Get your data.. then figure how to tackle it. Start on the easy..work from there.
The MAF sensor is one weird animal. Dont take it for granted unless you have swapped it with a known good one. This is the only sure fire test I know off. Three things that everyone who works on there cars should have, 1) spare ECM 2) spare coilpack/ignition module 3) spare GM MAF. The first two are easy to find. The third is getting tougher by the day.
Fly89gta, I'm of the thinking dont take the heads off unless you blow a HG. If they have the factory seal, leave them alone. If you do a lot of street driving, and occassional hammering here and there.. an alky kit makes the car more fun. And if you move up to heads and cam.. its not going to hurt to have it on either. So me.. I do alky first and leave the motor factory sealed.
You do heads first.. and you pop a HG becuase you had it off tune.. you'll wish you had alky.
trading t/a.. no problem bro.. I know you've been through the desert with yours.. I remember your first posts..
hehehe
116 is 7 bucks a gallon here.. 3 tank fulls .. the kit would be paid off.
