1KWIKSIX
- Sep 29, 2007
I’ve been running distilled water & RMI25 in my cooling system & decided to change over to ethylene glycol (anti freeze) for the winter.
To my horror I found my upper aluminum radiator pipe coated with a thin layer of surface rust .
I’ve run Evaporust ThermoCure cleaner thru the engine for 3-1/2hrs total & drained
What came out was a black coloured liquid.
Have drained the rad & filled with distilled water & run thru heat cycles several times , but still getting muddy looking water.
Believe the block needs to be flushed .
What’s the best way to do this ?
Any recommendations ?
I’d love to hear from you all as I believe there are several different ways to go about this task.
Thanks in advance
Thanks in advance
