Best way to pull this bearing from axle?
Chrisk
TurboTransAm.com
Whats the best way to pull this bearing out? Slide Hammer???
Thanks,
Chris
they make a bearing puller kit (three sizes) that inserts in and then allows you to pull it out (draw out actually)using a couple of wrenches , K-D Tools 41710 - Rear Axle Bearing Puller Kit
if your pullling them for c-clips elims i usually just use a 6ft length of 1/2" pipe and with just the weight of pipe sliding it in drive the bearings out from the back side
Both autozone and checker rent the slide hammer needed to get those out. I just did rear wheel bearings on my 91 burb.
Tarey
