My car has 109,000 on the stock motor. I'm not concerned with putting a ton of power through it right now as I have to still finish rebuilding my suspension (come on Power Performance Motorsports, where is my front end kit???), and then I'm going to dive into the tranny, and likely the rear after that. My goal with the car is low 11's at first with my ta-60, but I'd like the motor to be strong enough to handle mid to high 10's for the future after the 60. My question is, is it less expensive to rebuild the motor with 2-3 main caps, a girdle, and a roller? Or is it a better idea to do a budget 4.1 build (TurboBuicks.com - Build a Budget 4.1 Motor!) like this article over at turbobuicks.com. I have searched and it seems pretty common for these 4.1's to do low 11's really easily with not a lot of stress on the motor, apparently.
What route would you guys go and I'm assuming the heads, and all the 3.8 stuff bolts right up so you don't have to run a carb or anything like that. Well, I guess if you had to do that then no one would run a 4.1 :smile:
