I tried to mount a P275-60-15 bfg drag radial on
the stock rim. It rubs on the rear frame rail. Are there
any suggestions on what to do? I still want to use
the stock rim for stock appearances....
I got mine through Summit. I went with the 7/32". You may want to go with the 5/16". The PN# for the 7/32" is MRG-2370, and the 5/16" is MRG-2371. They are $10.95 and $11.95 respectivly.
My rear is off center a little. you might not have rubbing with the thinner ones. But then again.
They are in the wheel section if you have a catalog.
For a daily driver I would go for the aluminum drums as stated. Those spacers if universal do no fit quite right. I used the spacers at the track but also have to check to make sure the lug nuts don't loosen up! Hope this helps!
Tom
spacers work fine you may want to get longer studs depends on the size spacer stay with the smallest possible spacer around a 1/4 in. jegs sells the correct ones.
