BHJ Harmonic damper???????
Heath
Elroyjr
Is anyone using this damper? If so did u put it on your car out of the box? The instructions say to have your machine shop check your damper against your existing one to make sure it is balanced right. This crankshaft is new I do not have a existing damper to compare it to. :confused:
I understand it needs to be fitted. It is made on the small side and needs to be matched to the crank snout size.
The other thing is the crank sensor triggers should be verified for accuracy I heard reports of them being off.
