Intercooled88s
Moderator
- Aug 10, 2004
87 T Gray bucket seats $250
Gray Monte SS seats $200
84-87 T-type GM header panel, has some small imperfections $125
84-87 Grand National GM header panel, has imperfections $150
Rear Spoiler(5 pieces) GM, NOT aftermarket $190
Passenger head light bezel $40
Marker lights $40 each
Blackout wheel well moldings $60 each
T-type billet shifter handle $40
Heater box(complete NON AC heater box with heater controls, correct glove box etc.) $200
Astroroof parts, I have the whole set up but the glass is scrtched up, E mail with needs
87 GN complete engine oil pan to throttlebody, MAF to ECM, runs good $2600
87 BRF tranny $600
85 Turbo Riv long block $500
Parting a 84 Turbo riv ,Blue interior e mail me with needs.
4.1 block, std bore $300
Block(109 Block) $250
NOS drivers side rear wheelwell chrome trim $40
87 GN Grill $250(no cracks or chips)
87 Chrome grill $100
Blackout headlight bezels $80 for both
Blackout corner markers $80 for both
Front bumper fillers $80 for both
Rear bumper fillers $120 for both
86-87 GN concert sound lower door panels $100
85-87 Gray concert sound lower door panels $100
Blue Concert sound lower door panels
Concert sound speaker covers(light sand grey), just the speaker covers $60
Concert sound door speakers with mounting brackets and wire harness $75
86-87 GN console $170
85-87 Gray console $150
84-87 Consoles I am using for parts, e mail me with specific pieces
GN Dash Plaque(very nice) $100
86-87 Lower Intake(stock not ported) $170
86-87 Upper intake(dog house) $30
86-87 Fuel rail $35
86-87 throttlebody complete(sensors,throttle lever, vac manifold) $100
86-87 throttle cable $30
86-87 Up pipe $25
86-87 Cruise control assembly $35
86-87 Water pump pulley $25
86-87 Crank pulley $45
86-87 Main accessory bracket $70
86-87 Y bracket on back of Alt $35
86-87 Flat Y bracket on front of AC compressor $35
86-87 Turbo bracket $45
86-87 Intercooler brackets $40
86-87 Intercooler fan $40
86-87 Coil brackets $40
86-87 Headers(factory Exhaust manifolds,passenger side needs rewelding)$100
86-87 Crossover pipe $40
86-87 Power steering res. $60
86-87 Power steering res. bracket $20
86-87 Power steering pump $70
86-87 ECM $100
86-87 MAF $80
86-87 Coil/ module $100
Fresh set 8445 heads, not ported $100
NEW MSD 8.5 spark plug wires(84-85) $40
NEW IAC for 84-85 $30
NEW Power window motors $50 for both
86-87 T-type wheels $100 each
86-87 GN wheels $125 each
NEW after market header panel $80
Vacuum brake set up(master,vac assist and pedal) $65
Turbo crank Std/Std $250
I have every piece for 84-87 GN engines(stock) E mail if you dont see it.
D-5 convert $50
Grey/chrome strips on upper door(that pull strap attaches) $35 each in good condition.
Nice 87 GN wheels $500 for all 4
Maroon buckets need recovering $120
84 Gold bucket seats $300 with rear seats $400
E mail me for any other tan(Gold) interior pieces have the entire interior.
84 leather and cloth seats(84 T-type) ,Sand gray, in good condition $300
Power master $190
Hydrobooster brakes $100
ENGINE from 87 T-type(complete from oil pan to throttlebody/Maf to ECM) runs good $2500
87 GN long block $800
BRF tranny $500
BQ tranny $300
Electronic climate control(complete set up, will even include dash harness) $200
Passenger remote mirror(needs paint) $60
85-87 GN Front and rear seats in good condition(power driver seat also) $500
Original GN fender extensions for car with spoiler(good black paint/has the blue on the inside) $50 for both
84-85 GN Front air dam(spoiler) $75
87 Turbo T(T-type) dash plaque $60
84 GN dash pad $100
84 GN steering column $150
Maroon steering column with tilt/cruise $150
87 GN Nice grey column with tilt/cruise $150
steering column Non tilt $90
Any color seat belt set(10 pieces) $100
87 locking t-tops $150
84-85 Non key locking t-tops $100
84 GN seats(Front leather/cloth with embroidered 6 with rear leather/cloth seat) cloth needs to be replaced but
leather is good $200
87 GN wheels(4) in nice condition(with center caps and lug nuts) $600
87 GN Electric fan $50
Radiator hold down(plate on top that hold radiator and electric fan) $40
New Cam Position sensor CAP $40
Complete 86 T-type front clip $800
Fuel cell $60
Shifter with T handle $50
ATR Ram Air box with K&N built into it(the box is made of alum) $40
Bigger then stock front sway bar $70
Fuel sender/fuel hanger(analog gauge) $100
Hot Air to Intercooled Conversion: Includes parts to convert from 84/85 to 86/87 Intercooled setup. $1700
ENGINE PARTS:
AC compressor(84-85) $40
AC compressor(86-87) $60
AC lines(84-85) $40
AC lines(86-87) $50
Adaptor(86-87 oil return to block, brass adapter,screws into block in front) $20
Adaptor(85 Turbo to intake adaptor) $40
Adaptor(Oil cooler adaptor with nut) $35
Air Cleaner scoop(86-87 Scoop for airbreather) $20
Air Cleaner assembly(86-87) $25
Air Cleanerassembly(84-85) $20
Alt.(86-87) $60
Alt.(84-85) $30
Balancer(Turbo harmonic balancer) $80
Battery cable guide(Small plastic guide that holds the posi bat cable to the lower front cover) $20
Cam position sensor just the lower part(no cap) $30
Cam position (sensor with cap) $65
Chip(stock 86 chip) $30
Chip(stock 84 chip) $20
Coil pack(84-85) $40
Coil pack(86-87) $40
Control module(84-85) $50
Control module(86-87) $70
Connecting rods(2 dot) $40 a set of 6 or $10 for 1
Crossover pipe(84-85 Exhaust crossover pipe) $35
Dip stick and tube(86-87 dipstick and tube) $40
Dip stick and tube(84-85 dipstick and tube) $30
ECM(84-85 ECM) $40
EGR plastic cover $5
Elbow(84-87 Turbo elbow) $25
Flex plate(84-87 Turbo flex plate) $25
Fuel rail(84-85) $25
Fuel rail(86-87) $35
Headers(factory Exhaust headers,both sides)$100
Heads(stock 8445 heads needing rebuild) $50 a set
Injector harness(84-85) $35
Intake manifold(86-87 Upper intake manifold)$35
Intake manifold(84-85 GN intake) $40
Intercooler $45
Intercooler brackets both for $40
Intercooler fan $40
MAF(86-87 MAF) $90
MAF(84-85 MAF) $40
Main accessory bracket(86-87,the big alum. one) $70
Main accessory bracket(84-85) $40
Motor mounts(metal, frame mounts) $35
Oil pan(Turbo oil pan) $40 each
Power steering pump(86-87) $70
Pulley(86-87 Crank pulley with adapter) $40
Pulley(86-87 Water pump pulley) $25
Pulley(86-87 Alt pulley)$15
Rock arms+shafts(stock, complete set) $35
Throttlebody(84-85 Throttlebody with TPS,IAC motor,vacuum manifold) $40
Throttlebody(86-87 Throttlebody bare) $35
Throttle bracket(84-85 Throttle bracket) $20
Throttle cable(86-87 Throttle cable) $35
Throttle cable(84-85 Throttle cable) $30
Timing cover $35
Valve covers (84-85) $30
Wire harness(84-85 engine wire harness) $150
INTERIOR:
I have every color interior parts except Green.
Arm Rests( grey, red, Maroon or blue arm rests) $20 for 2
Arm rest(Light sage green arm rests(these are the rare light green color)) $30 for both
Concert sound speaker covers(84 GN) $50
Console shifter plate(Plate on console that goes around the shifter)$25
Dash pad no cracks(grey or Maroon) $100
Dash plaque(87 GN) $90
Door panels(85-87 GN lower door panels) $60
Door panels(85-87 T-type grey lower door panels) $40
Door panels(85-87 T-type Maroon lower door panels) $40
Door panels(85-87 T-type Blue lower door panels) $40
Gauge cluster(Analog) $80
Radio(Stock GN radio with cass, no EQ) $50
Sail panels(Grey interior panels around the quarter windows) for T-top car $40 for both
Sail panels(Grey interior panels around the quarter windows) for Hradtop car $40 for both
Seats(87 GN Front bucket seats need recovering) $150
Shifter $35(84-87 GN, needs T handle)
Steering wheel(good to have recovered) $40
Steering wheel(Tri shield GN horn center $40 no ring)
Steering wheel(T-type horn center $30 no ring)
Steering wheel(T horn center $30 no ring)
Surround(Gauge surround) $30
Surround(radio surround) $20
Third brake light(Grey, red, Maroon, or blue Third brake light)$20 Each
T-TOP trim around the t-tops on the inside of the car in, Maroon, grey and blue $20 for each piece
Visor(Nice blue passenger visor with lighted mirror) $20
Body Parts:
Blackout trim for front windshield $20 each piece or $45 for all 3
Blackout trim for rear window $20 each piece or $45 for all 3
Blackout trim around the door windows $20 each piece
Blackout Drip rails(hard top) $40 for both
Blackout(Trunk Lid blackout trim piece) $35
Blackout trim, T-top boot shaped trim that the T-tops lay on $60 for both
Blackout trim, T-top center trim piece, that the t-tops slide into $70
Bumper(GN Front black bumper) $50
Bumper(GN Rear black bumper) $70
Bumper reinforcement(Alum. Front bumper reinforcement)$90
Bumper reinforcement(Alum. rear bumper reinforcement) $70
Fenders(84-87 GN fenders(GM)) $100 each
Grill 87 GN Grill $250
Grill 87 Chrome grill $100
Grill 86 T-type grill $50
Grill 85 GN grill $60
Grill Emblem(85-87 T-type grill emblem) $15
Grill emblem(87 , says "Buick") $15
Lock set(all 3 locks with key) $50
Quarter windows with blackout trim $80 for both sides
Tail lights with blackout trim $90
tail lights with chrome trim $70
Mirror(Drivers mirror) $20
Mirror(Passenger Mirror,non remote)$20
Mirror(Passenger Mirror, Remote) $65
Wheel wells(Turbo plastic wheel wells) $80 each
Any other blackout piece e mail me I have them all
Hood(GN hood) $100-$250 (pick up only)
Hood Scoop(GN Hood scoop, cut from a metal GN hood) $50
Misc:
Antenna( black manual antenna complete with mast, base and nut)$40
Antenna base nut and spacer for Power antenna with black trim $10
Gas Tank(Turbo gas tank) $40 WON'T ship pick up only
Heater box(Complete heater box, For AC car) $100
PowerMaster(complete unit) $190
PowerMaster to firewall adaptor(bracket) $30
power trunk mechinism $20
Steering box(87 GN Power steering ) $35
Sway Bars(GN sway bars) $25 each
Transmission cross member $40
Tranny dip stick and tube $40
Transmission oil pan(Stock 200 4r tranny pan) $25
Valve body(BQ valve body $200)
windshield wiper assembly $15
E mail me at Fortune628@aol.com or PM me.(Best way to contact me.)
Cell number is 413 563 8819 , I DON'T check the voice mail on this number ever. If I don't answer just E mail me.
87 BRF tranny $600
86-87 Fuel rail $35
86-87 Up pipe $25
86-87 ECM $100
86-87 MAF $80
D-5 convert $50
Power master $190
BRF tranny $500
BQ tranny $300
84 GN dash pad $100
Fuel cell $60
ENGINE PARTS:
AC lines(84-85) $40
AC lines(86-87) $50
Alt.(86-87) $60
Alt.(84-85) $30
ECM(84-85 ECM) $40
Intercooler $45
Intercooler fan $40
MAF(86-87 MAF) $90
MAF(84-85 MAF) $40
Timing cover $35
INTERIOR:
Body Parts:
Misc:
