Intercooled88s
Moderator
- Aug 10, 2004
New Parts added to list
87 GN engine 82k complete original engine,with harness,ecm,MAf, all accessorys, turbo, intercooler etc, $1900
85 Hot air long block $500
Turbo hood scoop, cut from GN metal hood $50
complete heater/AC box $100
Headlight bezels (chrome bezels painted black, they look good) $25 for the set
8.5 Posi rear drum to drum $725 Sale Pending
Cottons Front mount with pipes $550
Fiberglass pin on hood Taking offers , pick up only
Hurst Floor shifter(Pistol grip Quarter stick for 200 4r) $100
Richmond 3.73 gears $140
Functional GNX louvers $100 (these arent the cheap stick on louvers on ebay, these actually vent air from the engine
compartment)
8.5 NON Posi rearend 3.42 gears complete drum to drum with driveshaft $500
New Caspers Coolant Hi-Lo Fan switch $20
AC delete Bracket with pulley $20
85 Grill $40
87 Engine 69k short block $1000
87 Engine 46k complete(Engine harness, all sensors, all accessorys, intercooler ect) $2400 Sale Pending
BRF tranny $500
D5 convert $50
8.5 rearend housing for GN $300
Stearing column from 87 GN $150
Dash Pad(grey) $100
Power Master 69k $200
Lock set (3 locks) $60
86-87 tranny dip stick tube $40
Locking T-tops $150
T-top boot shaped plates that the t-tops lay on $50
GN console $150
Dash harness $70
GN Concert sound 2 lower door panels $120
GN passenger seat in good condition $80
87 Grey passenger seat in good condition $80
Tail lights $100 a set
Quarter glass $100 a set
power trunk mechinism $20
Trunk Lid blackout trim piece $35
Blue console lid $30
New T-type emblems $20 each
T-type horn center $30 no ring
T horn center $30 no ring
T-type header panel $150
85 Turbo to intake adaptor $40
ENGINE PARTS:
AC compressor(84-85 AC compressor) $40
AC compressor(86-87 AC compressor) $60
AC lines(86-87 or 84-85) $45
Adaptor(86-87 oil return to block, brass adapter,screws into block in front) $20
Adaptor(Oil cooler adaptor with nut) $30
Air Cleaner scoop(86-87 Scoop for airbreather) $20
Air Cleaner assembly(86-87) $30
Air Cleanerassembly(84-85) $20
Alt.(86-87) $60
Alt.(84-85) $30
Balancer(Turbo harmonic balancer) $70
Battery cable guide(Small plastic guide that holds the posi bat cable to the lower front cover) $20
Belt tensioner(86-87) $70
Block(109 Block) $300
Cam position sensor just the lower part(no cap) $30
Cam position (sensor with cap) $65
Chip(stock 86 chip) $30
Chip(stock 84 chip) $20
Coil pack(84-85) $40
Coil pack(86-87) $40
Control module(84-85) $50
Control module(86-87) $60
Connecting rods(2 dot) $40 a set of 6 or $10 for 1
CONVERSION (84/85(Hot Air) to 86/87(Intercooled) conversion parts(all the original GN parts you need to convert
over from 85
to 87) $1400)
Crankshaft(Turbo crank will need to be turned to .010/.010) $250
Crankshaft(Turbo crank .020/.020, never run in engine) $150
Crossover pipe(84-85 Exhaust crossover pipe) $35
Dip stick and tube(86-87 dipstick and tube) $40
Dip stick and tube(84-85 dipstick and tube) $30
ECM(85-85 ECM) $40
ECM(86-87 ECM) $70
Elbow(84-87 Turbo elbow) $25
Flex plate(84-87 Turbo flex plate) $25
Fuel rail(84-85) $25
Fuel rail(86-87) $45
Headers(factory Exhaust headers,both sides)$100
Heads(stock 8445 heads needing rebuild) $45 a set
Injector harness(84-85) $35
Injector harness(86-87) $40
Intake manifold(86-87 Lower intake manifold)$130
Intake manifold(86-87 Upper intake manifold)$30
Intake manifold(84-85 GN intake) $40
Intercooler $60
Intercooler brackets both for $50
Intercooler fan $40
MAF(86-87 MAF) $80
MAF(84-85 MAF) $40
Main accessory bracket(86-87,the big alum. one) $70
Main accessory bracket(84-85) $40
Motor mounts(Engine frame mounts) $35
Oil pan(Turbo oil pan) $35 each
Power steering pump(86-87) $60
Pulleys(86-87 underdrive pulleys(crank and alt)) $35
Pulley(86-87 Crank pulley with adapter) $30
Pulley(86-87 Water pump pulley) $25
Pulley(86-87 Alt pulley)$15
Throttlebody(84-85 Throttlebody with TPS,IAC motor,vacuum manifold) $40
Throttlebody(86-87 Throttlebody with TPS,IAC motor,vacuum manifold) $60
Throttle bracket(86-87 Throttle bracket) $35
Throttle bracket(84-85 Throttle bracket) $20
Throttle cable(86-87 Throttle cable) $30
Throttle cable(84-85 Throttle cable) $30
Timing cover $35
Turbo(86-87 Turbo can be used as a core) $50
Valve covers (84-85) $30
Valve covers (86-87) $35
Valve cover oil filler tube(86-87 tube and cap) $30
Wire harness(84-85 engine wire harness) $100
Wire harness(86-87 engine wire harness) $200
INTERIOR:
Arm Rests( grey, red, Maroon or blue arm rests) $20 for 2
Arm rest(Light sage green arm rests(these are the rare light green color)) $30 for both
Console(85-87 GN) $140
Console(grey and shifter on the floor)$100
Console shifter plate(Plate on console that goes around the shifter)$30
Console(half console for Limited)(grey and shifter on column)$100
Dash pad no cracks(grey or Maroon) $100
Dash pad(Maroon dash pad, no cracks) $100
Door panels(87 T-type upper door panels) $60
Door panels(85-87 GN lower door panels) $60
Door panels(85-87 T-type grey lower door panels) $40
Door panels(85-87 T-type Maroon lower door panels) $40
Door panels(85-87 T-type Blue lower door panels) $40
Gauge cluster(Analog) $50
Light sage green seat belt guides $25 for both
Light sage green seat belt upper bolt cover, triangular shaped trim piece $20 for both
Map light $20
Radio(Stock GN radio, no EQ) $50
Sail panels(Grey interior panels around the quarter windows) for T-top car $40 for both
Sail panels(Grey interior panels around the quarter windows) for Hradtop car $40 for both
Seats(87 GN seats front and rear in great condition) $500
Seats(87 GN Front bucket seats need recovering) $150
Seat belt set(grey)(10 pieces) $60
Shifter $35(84-87 GN, needs T handle)
Steering column(grey and shifter on the floor)$120
Steering column(grey and shifter on the Column) $100
Steering wheel (Grey and in excellent condition(not redyed or recovered) with horn ring) $300
Steering wheel(good to have recovered) $40
Surround(Gauge surround) $35
Surround(radio surround) $25
Third brake light(Grey, red Maroon, or blue Third brake light)$25 Each
T-TOP trim around the t-tops on the inside of the car in, Maroon, or grey , all 6 pieces $100
Visor(Nice blue passenger visor with lighted mirror) $25
Body Parts:
Blackout door handles $15 for both
Blackout wheel well trim $40 each
Blackout(Front windshield blackout trim(3) )$40
Blackout(rear window blackout trim(3) )$30
Bumper(GN Rear black bumper) $100
Bumper reinforcement(Alum. Front bumper reinforcement)$100
Bumper reinforcement(Alum. rear bumper reinforcement) $80
Grill (86 T-type grill) $70
Grill(85 GN grill) $40
Grill (87 chrome grill painted black) $40
Grill Emblem(85-87 T-type grill emblem) $20
Grill emblem(87 , says "Buick") $20
Fenders(84-87 GN fenders(GM)) $80 each
Header Panel(84-87 T-type header panel) $150
Lock set(all 3 locks with key) $60
Quarter windows with blackout trim $100 for both sides
Tail lights with blackout trim $100
Tail lights with chrome trim $70
T-tops(86-87 GN locking T-tops) $150 a set
T-tops(84-85 GN NON Key locking T-tops) $150 a set
T-top black trim that the t-tops rest on(sort of L or boot shaped) $50
Mirror(Drivers mirror) $20
Mirror(Passenger Mirror)$20
Mirror(Passenger remote mirror) $40
Windshield blackout trim(3) $40
Windshield chrome trim(3) $30
Wheel wells(Turbo plastic wheel wells) $80 each
Any other blackout piece e mail me I have them all
Hood(GN hood) $95-$150
Hood Scoop(GN Hood scoop, cut from a metal GN hood) $50
Misc:
Antenna( black manual antenna complete with mast, base and nut)$35
Antenna base nut and spacer for Power antenna with black trim $10
Driveshaft for 8.5 rearend $50
Fuel pump hanger/sender $50
Gas Tank(Turbo gas tank) $40 WON'T ship pick up only
Heater box(Complete heater box, For AC car) $100
Hydrobooster brakes $100
PowerMaster to firewall adaptor(bracket) $30
Steering box(87 GN Power steering ) $35
Sway Bars(GN sway bars) $25 each
Transmission cross member $40
Transmission(BQ coded GN transmission 48k) $300
Transmission(BRF coded tranny) $500
Transmission oil pan(Stock 200 4r tranny pan) $25
Transmission(BRF tranny , missing valvebody and oil pan) $100
windshield wiper assembly $15
Wheels(86-87 T-type wheels for all 4 in good condition)$250 or 1 For $90
Wheels(86-87 GN wheels)good for cores all 4 for $100
E mail me at Fortune628@aol.com or Bobhebert574@aol.com
My phone # is 413 746 9668 I rarely check my voice mail so if you call and don't get me try again later. E mail is
quickest to contact me or PM.
compartment)
85 Grill $40
BRF tranny $500
D5 convert $50
Dash Pad(grey) $100
Locking T-tops $150
GN console $150
Dash harness $70
ENGINE PARTS:
Alt.(86-87) $60
Alt.(84-85) $30
over from 85
to 87) $1400)
ECM(85-85 ECM) $40
ECM(86-87 ECM) $70
Intercooler $60
Intercooler fan $40
MAF(86-87 MAF) $80
MAF(84-85 MAF) $40
Timing cover $35
INTERIOR:
Map light $20
Body Parts:
Misc:
