Big parts list... lots of oddball parts... lots of pics.
Beddy-bye time here
Sent $, if you need more LMK, other items become avail LMK
D
Well, I'm not exactly sure what you expect me to send you for $26 ??? :confused:
No prior exchange of info or PM's and no discussion about shipping ? and you just paypal me $26 out of the blue ???
$26 might cover shipping an empty box to Canada.
Updated list as of 11/13/09:
If it's marked SOLD, that means I've been paid for it and it's boxed, ready to ship... I don't consider anything sold until I see payment confirmation from Paypal.
1) Reman LS1 MAF sensor (no screens) $50 SOLD
2) Pass side kick panel upper trim only $15
3) Pass side kick panel complete (3-pieces) Chewed-up where Powerlogger plugs into ECM. $30
4) Factory injector harness $20
5) Factory GM used crank sensor and bracket $10 SOLD
6) Pile of new misc 231 header gaskets $10
7) Good ECM with bottom removed for Powerlogger attachment. (no dust cover) $40
8) Set of 12 pushrods 8.400” $40
9) Engine harness plastic cover (upper only) $15
10) New R42TS sparkplugs (11) $12
11) Small pass side VC breather (chrome cap missing) $5 SOLD
12) VC breather (used) $5 SOLD
13) VC breather (used) $5 SOLD
14) Used cam sensor cap (works) $15
15) New cam sensor (brand unknown) $65
16) Used Alky Control pump (older style but works fine) $50
17) Turbo heat shield (cut for THDP) $30
18) Battery hold down strap (used) $5 SOLD
19) Coolant temp sensor for gage (used) $5
20) Coolant temp sensor for ECM (used) $5
21) IAC + housing (used) $20
22) Biggie oil filter adapter (used, with marks on threads from channel locks) Still useable $15 SOLD
23) PCV 1-way check valve $15
24) VSS plug from back of instrument cluster $5
25) Fuel pressure gage 0-60psi 1/8” NPT (used) $15
26) Factory oil cooler adapter $20
27) Pile of TypeII coil packs and modules (used) $100 SOLD
28) Stock GN driveshaft with good U-joints $50 (pickup only / no shipping)
29) New upper radiator hose $10 SOLD
30) Factory water pump pulley $15
31) Factory crank pulley $30
32) Russ Merrit AC Delco plug wires for TypeII coil pack setup (used) $30 SOLD
33) Throttle cable / kickdown bracket $10 SOLD
34) Factory alt/ps/ac accessory bracket $30 SOLD
35) Cruise control diaphragm & bracket $20
36) Belt tensioner (used) $20 SOLD
37) Under dash sound deadener kick panels (driver & pass) (no juite material) $20
38) Factory linkage from column to trans $20
39) Factory vac lines (no PCV lines) $20 SOLD
40) 1” spacer for Dominator carb $20
41) CV893 AC Delco PCV valve $5 SOLD
42) CV893 AC Delco PCV valve $5 SOLD
43) CV893 AC Delco PCV valve $5 SOLD
44) Factory turbo drain line (used) $20
45) Autometer 1.5” gage mounting bracket $5
46) Autometer 1.5” gage mounting bracket $5
47) Wire support conduit for front of oil pan $5
48) Distributor/cam sensor hold down bracket $5
49) Heat shield for back of turbo $5 SOLD
50) Factory 200R4 shifter detent bracket $10
51) Factory spare tire hardware (used but very nice) $10 SOLD
52) Misc seatbelt guides $10
53) Remote trunk relase solenoid $15
54) AC condensor lower cushions & brackets + 1 upper cushion $5
55) Shifter plastic parts $10
56) Spring type cam button $5 SOLD
57) Under hood lamp assy $5
58) Washer nozzles & hose $5
Vac lines avail as discussed
shipped to 14216, need more $ I'll send more
OK, I gotcha... the Paypal screen showed you in Canada... I now see the NY addy in the comments section.
I updated the list to reflect you as the buyer on the vac lines. Lemme see what's spoken for as far as the other stuff is concerned.
And here I thought I would make things easy by listing all the stuff at once. ;)
That'll teach me. :D
These items are spoken for and awaiting payment:
6) Pile of new misc 231 header gaskets $10 Waiting on payment from "Burnout"
17) Turbo heat shield (cut for THDP) $30 Waiting on payment from "Davinci50"
19) Coolant temp sensor for gage (used) $5 Waiting on payment from "Chris Garrett"
20) Coolant temp sensor for ECM (used) $5 Waiting on payment from "Chris Garrett"
21) IAC + housing (used) $20 Waiting on payment from "Chris Garrett"
44) Factory turbo drain line (used) $20 Waiting on payment from Tony / "3.8 V8 Eater"
48) Distributor/cam sensor hold down bracket $5 Waiting on payment from "Chris Garrett"
57) Under hood lamp assy $5 Waiting on payment from Tony / "3.8 V8 Eater"
I'll get paypal setup when I get home. Can you let me know how much shipped to 51109 for the plastic shifter parts (55)?
Updated list as of 11/13/09 - 11:30am eastern
Items I've given payment instructions for, are marked accordingly... "Waiting for payment from ____"
4) Factory injector harness $20 Waiting on payment from Don at 48035
6) Pile of new misc 231 header gaskets $10 SOLD
9) Engine harness plastic cover (upper only) $15 Waiting on payment from kevinw25645
10) New R42TS sparkplugs (11) $12 Waiting on payment from Don at 48035
19) Coolant temp sensor for gage (used) $5 SOLD
20) Coolant temp sensor for ECM (used) $5 SOLD
21) IAC + housing (used) $20 SOLD
37) Under dash sound deadener kick panels (driver & pass) (no juite material) $20 Waiting on payment from JDsfastGN
38) Factory linkage from column to trans $20 Waiting on payment from kevinw25645
48) Distributor/cam sensor hold down bracket $5 SOLD
55) Shifter plastic parts $10 Waiting on payment from ustaboost
I'll take the (35) Cruise control Servo and (53) Remote trunk solenoid. Please let me know how much for shipping to 11704.
Thanks.
Updated list as of 11/13/09 – 4pm eastern
4) Factory injector harness $20 SOLD
9) Engine harness plastic cover (upper only) $15 SOLD
10) New R42TS sparkplugs (11) $12 SOLD
35) Cruise control diaphragm & bracket $20 SOLD
37) Under dash sound deadener kick panels (driver & pass) (no juite material) $20 SOLD
38) Factory linkage from column to trans $20 SOLD
44) Factory turbo drain line (used) $20 SOLD
53) Remote trunk relase solenoid $15 SOLD
55) Shifter plastic parts $10 Waiting on payment from "ustaboost"
57) Under hood lamp assy $5 SOLD
This is a condensed list of what is currently still available and not spoken for:
I'm gonna pass on 55. A guy I'm getting some brake parts from has one of these. Thanks for your time
Updated list as of 11/14/09 – 1230pm eastern
17) Turbo heat shield (cut for THDP) $30 SOLD
26) Factory oil cooler adapter $20 Waiting on payment from "bpalma"
47) Wire support conduit for front of oil pan $5 SOLD
55) Shifter plastic parts $10 SOLD
This is what’s still available.
Updated list as of 11/16/09 – 5:00pm eastern
Anything not on this list has been paid for and shipped already.
