ryan george
- Jan 17, 2007
A little history. 2 falls ago i popped my first head gasket after owning the car for 20+ years (no log, powerlogger didn't record the run). I run mid to high 20's for boost, so i don't baby it. That following spring i decided it was time to upgrade since the head gaskets needed replaced. Had Dan @ DLS rework the stock heads for a roller cam and do some cleaning up to the heads to get more flow (not a full port job, told him i wanted a mid 10 sec car so that's what he recommended). After a few problems with the install, I had the car back. Did the required break in time. Then, decided to run straight race fuel instead of alcohol as I didn't trust the alcohol system with the boost in the high 20's. This included a new chip from Eric at TT.
Was working on tuning (I'm not the greatest, admittedly, always fat,, haven't had help from anyone but I do try), starting with boost in the low 20's and working my way up. I had probably made 8 - 10 hard pulls up to about 105-110mph with no knock (none expected with the race fuel) over the course of having the car out 5 or so times (don't recall). I have also had an oil leak issue that coated the underneath of my car since the rebuild. Have not been able to trace it, but I think it's the breathers on the new head covers. I opened them slightly as a few directed on here, but to no avail. Recently, I cut them completely open as my others were, but with the car being down, no idea if that fixed the issue.
So...I have a buddy over helping me work on a shower and we get it done and since he's never been in the GN before (it doesn't get out much) I decided to take it out for a spin. It was running good. Launched hard on no or very little boost. Drag radials broke loose a little ways out then grabbed. Felt like they may have broken loose a little again. Then a big pop and the engine dies. I'm able to get it off the road and figured that my stupid up pipe had blown off, no big deal. Check, and it's on tight. Try cranking the car over and it cranks and cranks but nothing. Plug wires are connected. I have fuel pressure. ECM connections are tight. Cam sensor was suggested as another possibility, but I pulled the cover and it's tight. I just now (after probably 8-10 months) started to go down the no start tree on Steve's Vortex Buick site, but I don't have an injector test light (yet), so I thought i'd check on here to see if anyone quick ideas i can check. I did the spring oil change and just put in a new O2 sensor, but that's it so far.
Haven't done anything with the car for this long because I've been busy, but mainly really, really frustrated and disappointed. Just feels like ALOT more money pissed away for nothing. I've had the car for almost 25 years now and I unfortunately keep finding myself asking why I don't sell it. That sucks.
Appreciate suggestions. Thx.
