Today I drove my car 250 KM about 200 miles. (No smoke). My oil pressure after warm up sits at 30 pounds during idle and 40 pounds cruising as I accelerate the pressure goes up. This is what I did prior to driving it. I opened the valve cover breathers from the inside some more, they were only opened a little (inside the breather is a splash guard to keep the oil in, with a small opening), I installed a known good PCV valve and changed oil and filter, running mobile 1 10W30. Now everything appears to be good. My new build has 780 km (500 + miles) on it now and is running better with every mile. I'm having a hard time finding a new PCV valve here in Canada. Tomorrow I will try NAPA any suggestions would be appreciated.
Thanks Ted
If all else fails on your search for the correct PCV, look up Kirbanperformance.com. Have one shipped to you.
Let's keep in mind that the PCV was the issue, not oil pressure.
