Biggest turbo on stock heads/cam
V8killR4U
Whats the biggest turbo i can go with, with stock heads and cam. Reason im asking is i dont want any boost pulsing.
You got alot of room for adding more fuel.
72 wouldn't be too big for a 60.
Thou 55s would get you by.
And of course a supporting fuel system.
There are guys on here running TE-45a's/TE-64's etc on stock longblocks with high stall convertors.
What et goals do you have?
I don't think upgrading from a TE-60 to a TE-61 is really worth it do you? If you need more grunt get a big shaft turbo.
-GNX7
I run a T63E on a stock long block with an art carr 16930. It is a little laggy from dead stop but not too terrible.
HTH: Jason
70 Innovative double ball bearing P-trim.
3200 stall is all you need. :cool:
