Biggest Turbo
donZ
what is the biggest turbo, you should run with a stock bottom end, and stock heads and cam,:confused:
Don,
I would try the PT-61 from PTE. Get the one with the 52 exhaust wheel. It will spool like a mother, and make great power. The P-trim may spool to slow on a car with unported heads. I went 11.2 @121 with my PT-61 at 21psi.
Brian
Brian is right on the money...the P-trim will work with a 3200 rpm "flash stall" speed awesome...if you want mild then do the 52 wheel with .63 A/R for quick spool on say a 2800-3000 stall...will be putting a P-trim on my car with bone stock motor internals minus timing chain, gears, and valve springs...
