biggest turbo
turbogus
i want to know what is thr biggest turbo i can run with stock t q and my 009s thank you
TE 62 should work well..or PT54..both are kind of old school but heavy breathers..maybe someone else knows of the modern equivalent..
Stock torque converter and 009 injectors, I would say it would be a PT6131E or PT6131RE turbo.
Anymore than this turbo, and you would surely be out of injector. Actually, this turbo will make enough power to completely max out the 42.5# injectors.
Turbo is rated to support 590-600 flywheel hp.
Injectors will support 510 flywheel hp when maxed out. So honestly, you'd be about done at around 24-25psi of boost with 009 injectors.
In my opinion, I'd slap some 60# Mototrons and a TT chip and be done with it.
HTH
Patrick
