Billet 2004R with Stage-Right brake, Art Carr pan, Shifter plate
Intercooler
Trans has 150 miles on it and 90 of that is highway. Only 4 track passes in the 11's. The trans was built by DelTrans in Newark, DE. It is an 87 BRF core with a CK Performance billet input shaft and drum, PTS billet band anchor pin, hardened stator, Stage-Right trans brake, Art Carr modified deep pan for 700 bottom feed filter with temperature sender and is set up for a lock-up converter. I have receipts for the billet parts totalling $750 alone. I will also include the shifter plate I purchased from Century Transmissions to replace your stock shifter plate when using the Stage-Right brake. I can get a transmission shipping container and ship it anywhere in the U.S. or Canada via FedEx Ground. It weighs about 130 lbs which makes it because I have done this before. $1500 plus shipping for it. Awesome piece for that kind of bread.
