Guys,
After getting my new engine in, I promptly blew a brake line on the rear axle and all of the fluid leaked out. I replaced the lines and went to bleed the system (vacuum setup). I seem to recall something about pressing the button on the front of the proportioning valve to allow bleeding, but I can't find any info about that here when searching about bleeding the brakes, plus the button does not seem to want to move.
Anyway, the rears will not bleed via gravity or mighty vac, so I'm guessing i have to do a better job bleeding the master cylinder vs. opening the lines at the side of the MC and letting fluid leak out.
I would imagine my process should be:
1. bleed the MC with a bench bleed type kit
2. crack the lines at the proportioning valve to be sure that's set
3. then bleed the brakes as normal (right rear, left rear, etc.)
Any one have info on the proportioning valve deal, or idea why the rears won't bleed other than the above?
Thanks.
Thanks.
