oneslobuick
- Dec 12, 2002
ok first this car has had this issue for a while and ive not driven it in a couple of years so recently i decided to blow the dust of it and try to resolve the issues once and for all so any help would be appreciated.
scanmaster results (warm idle in park)
o2 219-730 all over the place
AF 07-08
L8 49
bat 12.9
int 179
bl 107
clt 167
ats 86
r 950-1050
tps .44
iac 150
maf 00
ok before you ask this is what i have tried
replaced o2 with gm
replaced iac with gm
iac reset procedure 100 times
i have lowerd the fp down to 22 lbs line off bl# go up but not enough
no vacuume leaks (trust me)
pulled the plugs all are equally over fueled
fuel pressure stays after the car is shut off so idont think leaking inj
tried different chips and ecms an generaly the same # on scan master
now my questions may be silly but here it goes.
if the maf is 8 why is the iac 150 shouldnt the iac cut back air to compensate
and even if the maf is 8 why can i not take enough fuel out to get the blms up
please hurry before makes me sell it or she leaves me!:frown:
AF 07-08
L8 49
bat 12.9
int 179
bl 107
clt 167
ats 86
r 950-1050
tps .44
iac 150
maf 00
replaced o2 with gm
