Um, If you turn up the fuel psi, which you need to do anyway since 37# static is a little low, imo, the BLMs will go down/lower. If they get to 90, or there abouts, it's time for a chip adjustment. I would suggest tuning FP for WOT, for no/low Knock, and then see what the BLMs look like at idle, etc. Then you can decide if the chip's off. Although I don't make chips, it's probable that chip makers have certain perimeters they use when burning you a chip. Such as Inj., Cam, Turbo, etc. Since all cars work a little different, sometimes a chip adjustment is needed. The computer will correct BLMs to a point, but, the most important part, as far as FP goes, is WOT. That's where those pestky headgaskets go out.
