86DarganGN
 - May 9, 2012
I would contact iskey and ask what the recommended spring pressure is for that cam. Stock tb springs are just ok for the small stock cam. That cam may need a little more pressure to keep the valves from floating.
Thanks so much for your expert advice, I will transfer it to Rod at Liskey.Here is my opinion:
I am sure he sold the cam to other TB customers and it would be interesting to hear his (Isky's) theory and real world results with so much overlap in a turbo application?
If "I" wanted a lopey cam . . Sure . . I would use it. Not saying the cam is the source of the KR but think about the air making it to the O2 sensor under low load . . . countered by the neg impact on mass flow at boost from BP and reversal.
Hope you find the issue(s) as it can be very frustrating.
