Pronto
No amount of evidence will ever persuade an idiot.
- Dec 9, 2002
If you don't have access to race gas you can try Boostane. Cal Hartline had good results using that on a dyno tune session. You adjust the octane rating by the ratio. Don't know about the Lucas booster.
You are pressurizing your block if you have oil soaking the breathers. Put a check valve in the PCV line or eliminate it. I would do a pressure test on the intake to check for vacuum leaks. 132 is a little lean so there might be a minor leak.
I'm not familiar with the Red's chip. Not sure if a TT chip burned for your exact combo might have a better handle on the tune. At least it would be adjustable.
