After measuring my block with a bore gauge and getting a second opinion from a machine shop, 4 cylinders are severely tapered inward. My block was sleeved in all cylinders by a previous owner and the 4 outer cylinders are in spec until about 2/3rds the way down where they start to taper in greatly. The machinist I went to said he could bring the block back into spec. The engine is at .040 over and at some points the taper is .005 inward but he does not have a torque plate nor did he think one is required. The two center cylinders and main clearances are all good for what ever that's worth.
My question is how best to proceed? Should I order a torque plate, should I let them him do it without a plate (machinist's suggestion) or should I toss the block? I live in the Dominican Republic so my machining options are limited to this shop only.
My goal is to have a reliable stock street engine. Any and all advise would be greatly appreciated.
Thanks,
rob
Thanks,
rob
