Block going to the machine shop, need advice please!
WSLN 6
Powered by Murphy's Law
I have the engine out and it is waiting for parts. I will be taking it to the machine shop soon, but didn't want to miss any steps.
Is there anything I should be doing to the block to prep it?
Any modifications at all?
Advice is appreciated!
Sean Friesen
Why is the engine going to the machine shop?
What do you want to accomplish? What is the goal?
Sorry, I will give a little background.....
Freshening/strengthening the stock block.
Adding:
Girdle/main studs
Roller 210/215 cam w roller rockers
Forged pistons
polish the stock rods (good idea?)
Hopefully the crank will be ok with a .010 cut, hopefully .020 on the pistons
Just was wondering if I needed to do any kind of modifications before the block and crank go in.
Fire away!
Get your hands on a Buick Power Source manual. It is chock full of tips and tricks for prepping a race-ready block.
A few years back when I built my first engine I asked the machinist if I should clean up the rods and the crank of the casting flash. He said I could if I wanted to but it wouldn't matter. Since he's been in the business for 30 years and had Buick experience I believed him and it's proven correct. My stock uncleaned rods are resized only and the stock uncleaned crank is approximately .010 under. 9.98 @ 136.
What is important in my opinion is that the machinist installs the girdle and main caps according to Jason's instructions, plus uses a torque plate, in order to do the necessary boring and align honing. My machinist will then disassemble it, install the mains and measures what he needs, in order to have the crank turned to that less .002. On each throw.
The only thing I'd do in your case is talk to the machinist and be assured by him that he will use a torque plate and install the girdle before the machine work. And hopefully he knows Buick V6's are different than Small Blocks. It's not what you do at this pont, it's what he does that matters.
I heard about this manual and have YET to see a place where I can purchase one. Any idea on leads?
Chris.. great reply.
I sent my caps to Jason for milling. The charge is like 125.00. Then I setup my own girdle, dropped the crank in with bearings and confirmed an alignment issue. Left the spacing on the loose side. Took the block to my local guy that line honed it. The charge for that was 125.00. And he gave me back a shortblock with a set crank. Then pulled the shims and setup the gap to 5 thou all the way around.
My rods I put the ARP bolts and resized them.
Crank is polished, pistons are stockers. Rings speedpro's plasma moly's.
Installed screw in freeze plugs in the oil galley holes. Had the machine shop install the redrilled cam bearings. Hone cylinders.. wash block.. did all my own assembly.
Talk to Jason on the caps.. he's done quite a few.
HTH
