Block Oversize Qestion
BuickNewBee
Block Oversize Question
I have the heads off my block and the pistons are .40 over.What is the safe oversize with these 109 blocks 20# plus boost Should I worry or get a new block?
Guys are running .040" over but I wouldn't feel comfortable going over .030" over.
You can run .050 to .060 over pistons, but it will make the car run hotter. Not recommened for 11 sec car or faster.
If you need a block I have some standard 109 turbo blocks for sale $350.00ea
Good Luck
I ran a couple of .040" motors with no problems. You should be fine in the mid to upper 10's with that bore.
