Block threads for head bolt stripped
kidrick
I finally got around to replacing my head gaskets. I was followig the Fel-Pro directions to torque the ARP head bolts for my GN1s(loc-wire gaskets). I worked my way up to 75ft/lbs. on all the bolts and then set the two longer ones at 85ft/lbs. I went back to check the #1 bolt at 75ft/lbs and it let loose and just kept spinning. Yes, I double check after this happend and the torque wrench was at 75ft/lbs. I pulled the head and metal threads from the block were caught in the bolt treads. I cleaned the bolt and threaded it back in the hole with no head on and it went in an then bound up. I tried the same bolt in a different hole and it went in fine. What are my options to repair this? It is a stock block.
Thanks.
that sux man! Try to re-thread the hole. If that don't work, your gonna have to pull the engine send it out to the machine shop.......... :mad: or, I'm not sure, how far does the bolt go in? can you get a stud in there???
I did a better search and would use helicoil #5521-7 and a 29/64 drill bit for the repair?
Stock block, ARP bolts.
