Blocks, Heads and Timing Covers
turbo6randy
109 Engine block $350.
8445 Heads $50. pair
Timing Cover $35.
Have at least two of everything available. Plus shipping.
I have three that are standard bore but will need to be bored due to wear in the cylinders. These were removed from normally aspirated cars so they will need the turbo return line hole to be drilled and tapped, which I can do for you at no charge. Blocks all are in good usable condition but mileage is unknown. Also have a .030 over block that was out of a turbo car which could be honed and reassembled.
