thanks for the replies
no scanmaster as of yet, i was at my wits end with this and wasn't trying to come off harsh or like an a55. So if i offended someone i aplogize. now i found a broken vacuum line on the passenger side of the breather. it's the hose that goes into the intake closest to the passenger side of the firewall and T's off and goes across to the drivers side and back down. I just saw this within a few hrs and am in the middle of fixing it. Also there's some oil being thrown around my oil cap breather. So i'm cleaning the engine AGAIN, and seeing if this will help. The PVC valve i bought wasn't an AC Delco but i will be buying one tomorrow when the shop i normally do business with is open. I also put a 45 degree angle elbow on the passenger side breather and when i was cleaning the breather with the K&N refresh kit i noticed that the breather on the passenger side didn't have a sponge in it. Should it have one? I have one available but don't want to press my luck with it being sucked into the engine if there is pressure ( can this actually happen if i do put a sponge on it ). I was thinking maybe that was part of the problem, but after i put the elbow on it it was still doing the blowby. So I'm working on it, I really am going to pick up a scanmaster soon. From what i'm gathering this is a MUST HAVE tool for these cars. I was putting it off but if it can help narrow down the little things and help point you in the right direction then it'll be the next upgrade. Thanks again guys for your replies, i'll let you know how things shape up with this. and again i wasn't trying to come off as an a55 so please understand as i'm sure some of you guys have been there when little things like this happen and you cannot narrrow it down. I'm not the type to go off like that. I'm normally the cool head but with this car being in my hands less then a month i know this will be a learning process and instead of blowing my top on something minor i normally step back take a breath and cool off.
