G
G-M
Guest
i have a smoking problem, no pun intended after acceleration i have a huge smoke cloud under the hood ,i was told the O ring on the oil filler cap is bad , but what i feel what may be the problem is blow by ,and what's happening is when the turbo builds pressure it's filling the crankcase with pressure and sending oil right pass the rings and blowing it out the oil filler cap,i only get the smoke after boost and then it clears up untill i jump on the car again,,the turbo itself is a 1/4 mile performance turbo in atco new jersey and im assured the turbo is not the problem and it has been set at 5-6 lbs im new to the turbo GN's any advice would be greatly appreciated
thank's ,
Rick
thank's ,
Rick
