Not an electrician but, thought I could handle this. Having trouble getting my blower motor to run on high and or run at all. Bear with me as this seems crazy to me. With key on --eng. off--car has been sitting for a few weeks--back of alt. shows 11.8 volts. If I turn blower motor on any speed up to but not including high, I am getting 11.7 volts @ the terminal that plugs into motor. 8.5 on high. I have the treminal pulled off the motor spade. Put it on motor spade and nothing. Remove terminal and using a jumper wire from back of alt. to motor spade and motor runs. Couple times today, out of the blue motor starts running --go inside and turn to high and it stops and won't restart on any speed untill it decides it wants to. You would think if I have 11.7 volts to terminal --plug terminal on to spade and motor would run--NOT--what am I missing. Open to any and all suggestions. Thanks--Lee
