turbobooster
- Nov 12, 2002
Ok so since I have my crossover pipe out right now , I want to replace oil pan gasket . I have searched and read many different opinions on gaskets I’m going with cometic , the question I have is some people lift engine up remove bolts from motor mounts hand turn crank to drop the pan is all this necessary ?how are you guys doing it ? Looking for the least complicated way to change this out any tips and advice is greatly appreciated thank you
