John Larkin
Sublime Master of Turbology
- May 25, 2001
I thought I was going to have to buy a new relay, the metal one that hangs on the a/c box. I separated it from the connector, gently pried open the 4 tangs and removed the metal cover. There is a set of contacts inside. When these contacts close, that is what gives you the high speed (4th or top switch position) blower. Dragging a piece of sandpaper through these contacts cleaned them enough to let the red wire feed 12 volts to the purple wire on the connector. Voila, high speed blower for $0.
FWIW, the voltages you see at the purple wire in the connector should be as follows: low speed 3.2v, 2nd speed 5.8v, 3rd speed 7.5v, and high speed 12.0 (maybe 11.9). The red wire 11.9v - 12.0v all the time with the key on. The blue wire should match the purple wire voltage.
Just thought I would share.
