whitehot84
- Jun 6, 2001
Guys, we've seen this problem many times. It usually is in the weatherproof plug behind the heater box. Look for the wiring harness where it comes up from under the passenger side hood hinge. Take it apart and clean both ends of the connector very thoroughly. Put some dielectric grease on it before putting it back together. Some of our cars have the high speed relay and some just use straight 12v from the fuse block for high by bypassing the resistors. The resistor bank only affects the lower speeds.
Good luck.
Good luck.
