blowing dipstick out
QUIP'6'
Brian Roman
when i jump on my buick i blow the oil dipstick out. what would cause this and what is the remedy.
Are you using aftermarket valve cover breathers and/or grommets? I put grommets in that were designed to keep splash oil out of the breathers ( they had slits in the bottoms for venting ) Dam near the most restrictive things known to man. cut out the bottoms and the problem was fixed. HTH, Brian
kn filter on the ps cap on driverside pcv working good. think i might have a blown head gasket car heats up fast no circulation in radiator hose get rock hard and compression 145 145 140 140 138 120 low on #5 cylinder bad performance too. was only getting 20# of fp at idle got walbro 340 and hotwire kit now i got 35#
