benmorgan82
- Nov 17, 2009
Ok so I parked my truck that has 87 GN engine in it and 2 weeks later go to start it. I hear the fuel pump run crank it and it starts for 2 seconds then dies. Crank Crank Crank no start. I look at FP guage and down to 10 psi and I just installed a walbro pump so I figure its good.
So I start checking fuses and find ECM fuse blow. I change it turn on key hear fuel pump run, crank it and then the same thing happens again.
Any ideas on where I should start? Common problems?
