I need help trying to fix a friends car. Every time he tries to start his car the fuel pump fuse blows in the fuse panel under the dash.
1) We have disconnected the hotwire kit and rewired the fp the with the stock wiring still no luck.
2) We also disconnected the fp relay and it still blows the fuse. Before the fuse blows the relay clicks so it's getting power. I also disconnected the fuel pump wiring harnass to the fuel pump to rule out the pump it self.
3) I was instructed to check the wire behind the alternator and the oil pressure send plug. But both checked out ok.
The car was running fine last summer and he put it away for the winter and then went to move it a couple days ago and this all started. Any one with similar problems that can help?![Confused :confused: :confused:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f615.png)
