Blowing fuses
levorn10
I tracked down why the brakes got very hard on me. Turns out the fuse was blown. I installed anew fuse and the motor ran for about 30 seconds and quit. Again, the fuse was blown. I put in a new fuse again and started the car and the fuse blew immediately. I have no idea what the problem is. When the motor runs, the brakes are fine.
Help!
when i first bought my gn i blew the brake fuse about 3 times within about 3 days. then it stopped and they worked fine for several more years. never figured out the cause. if you're blowing them that fast though, something is not right. i'd guess the pump is trying to pull too much juice for some reason. probably needs rebuilt/replaced. arent PM's great? :rolleyes:
