Blue smoke
nitrousmike175
How can i tell if the intake is pulling oil in the runners without pulling it off? The car only smokes under acceleration.
THANKS MIKE!!!!!!!!!!!!!!!!!!!!!!
Just a guess,you could check your vacuum line from the pcv valve to upper intake and see if is coated with oil. Any knock? Good luck.
You can just pull off the doghouse and look for oil residue in the upper and lower intake.
If the turbo is bad, just pulling the up pipe may reveal residue.
Also check the PCV, it may be stuck open.
I moved the pcv valve to the valve cover because it was sucking oil and still have the problem. No knock.
THANKS for the help!
Thanks for the info i'm going to pull it off and check that.
