Ok, I've got a '86 GN, I was changing my body mounts when I ran into a problem.
I got all of the passenger side mounts switched with no problems at all, I also got the rear, #5 installed, and the #6, #7 and #4 installed. I put my T-bar made out of 2x4's under the door, just as I had done on the passenger side, and as I jacked it up, it only went a couple inches.
I couldn't get the #2 or #3 bushing out of the car... as I turned my creeper, I bumped the jackstand, which was an inch too low! I got out from under there as fast as I could... and replaced the jackstand under the frame. As I lowered the jack, the frame went also. My frame is stuck to the body! I've removed all the bolts for the bushings, #1-7 on the drivers side are not bolted in, on the passenger side, they're in place, but not tightened.
I can't figure out what the hell would be holding the frame to the body... the only things that I can see are attached to both the frame and body are the linkage from the tranny to the steering collum, the brakelines and the steering shaft from the colum to the power-steering pump. I can't immagine that any of that stuff would keep it from lifting off the frame.
I do have the bumpers off of the car.
Any ideas? It's got to be something really stupid I just haven't thought of.
