Bolt in Ford 9" rear end for G Body
rear end
Currie sells complete bolt in rear ends that you can use your stock brakes with, I believe Moser does also. HTH Dan
Ford 9 inch, $1000
I have one in San Antonio, TX. 3.70 gears, 28 spline axles, Limited Slip, 11" Ford brakes, drum to drum with parking brake cables. Was in a 81 Malibu behind a Big Block Chevy, can include the driveshaft for a Turbo 400 tranny (I might be wrong on this part, might have been a 700R4). $1000 plus freight type shipping (terminal to terminal or business address with a liftgate available). Thanks.
I don't have one for sale but I do have some advise. The 1000.00 is an excellent deal if you are intent on a 9. I installed one in my '86 a year ago. I didn't think about pinion angle. I bought a set of adjustable upper contol arms to adjust the angle. I bought the kind with solid bushings. They were to noticeable so I replaced them with Hotchkis w/poly bushings. I will sell the first arms if you need them. I also needed a new drive shaft. My point is, if I had it to do over again, I would have installed a new 12 bolt which doesn't require all the extras. One of the advantages of the 9" is, I was running a 3:50 but with gas prices I changed it to a 3:23. The 1000.00 is a good price. I probably have around 2500.00 in what I have bought..
ford 9'' for sale
I have a ford 9'' limited slip with 4:11 gears with a 700R4 behind it in my 80 malibu ford brakes drum to drum i am asking 1.200 OBO for it i am in long beach ca. and i see that you or it las vegas so u or just a drive away
