Aug 25, 2004 #1 8 83ttypeboi New Member Joined Feb 27, 2003 Messages 22 wut is the bolt pattern to an 83 ttype?
Aug 26, 2004 #2 F fuzzyGN Member Joined May 3, 2002 Messages 702 For what? The wheels? The wheels are 5 on 4.75"
Aug 30, 2004 #3 8 83ttypeboi New Member Joined Feb 27, 2003 Messages 22 yea thats it thanx...now another question, my water pump/alt belt came off. but i nolonger have a/c and heater connected. is their a smaller belt i can use to not run the heater pulley and jus run the alt/wp? thanx
Sep 1, 2004 #4 b4black Well-Known Member Joined May 24, 2001 Messages 3,773 The air conditioning belt shouldn't drive the alternator. It goes around crank, water pump and AC compressor. The other belt goes around the crank, water pump, alternator and AIR pump. You should be able to remove the AC belt and the other belt will drive everything else.
