bolt pattern
yea thats it thanx...now another question, my water pump/alt belt came off. but i nolonger have a/c and heater connected. is their a smaller belt i can use to not run the heater pulley and jus run the alt/wp? thanx
The air conditioning belt shouldn't drive the alternator. It goes around crank, water pump and AC compressor.
The other belt goes around the crank, water pump, alternator and AIR pump.
You should be able to remove the AC belt and the other belt will drive everything else.
