Clear as mud - anyone know anything about setting this thing? What is this secondary trigger stuff? I simply want to just turn the knob to increase the boost. Doesn't seem to want to give me more than 20 psi.
if stuck at 20 youll need an adjustable wastegate actuator (shorten the rod ), and you can also hook up two solenoids (caspers has a plugnplay harness for it ) to increase the venting and the boost controller should be able to adjust twice what a single can or about 8psi
if you still cant reach your desired boost a HD actuator might be needed
and second stage would be the trigger from 3rd gear in trans so you could run more boost in 1-2 and then have it drop boost back when going to 3rd as the stock ecu does
I have an adj wastgate rod and a HD actuator. I have the switches all up (or off) . Any idea why the dial on the front won't let me turn it up past 20? How much will it cut boost back in 3rd gear from 1&2. Is this cutback automatic?
