Ok, first off I tried to search a couple times but it keeps saying "site not responding yada yada yada" So my question is, I have a manual boost controller (the kind you keep in the car with you) and also have an adjustable wastegate rod. From my understanding using the knob is better then the rod since the rod will start to open the puck before the desired boost level is reached meaning you will probably spool a little slower on the top end. So, I have the controller hooked up now where should I set the rod to? Should I make it really loose? Thanks!
