TampaTurbo
- May 13, 2003
I have a te44 on a stock converter. I heard a boost controller may help increase the spool some. Is there anything to this?
SignUp Now!lpaulabbott said:
MoeJr said:How come you stopped selling them Sinful? They sound awesome.
tsaltario said:I have the BSCT boost controller in my GN, and was looking at these valves. Does my bsct boost control keep the puck closed longer too? or is this a worthwhile upgrade?
TJ
Steve V said:The controller in the pic looks just like the one QBoost was selling a while back.
TampaTurbo said:I have a te44 on a stock converter. I heard a boost controller may help increase the spool some. Is there anything to this?
JoeNational said:I have the BstC controller and works like a charm. Quick install and gives you some cool features (third gear boost control). You have to splice into the ECM which can be a little tricky as it is the ECM and dont want to mess anything up. I soldered(sp?) everything so that I know I have a good solid connection. you get 7lbs of play with it. In other words you adjust your wastegate to lets say 14lbs you can then turn that up to 21lbs using the controller and so fourth. I bought mine used for $100 but a new one can be had for rougly $150. I know other guys use manual controllers as this is an electrical unit. I run this along with alky kit and it is a great combo![]()
