You won't be able to run that low of boost with the RJC unit installed. It has a built in air bleed to allow the actuator to close, as a side effect, it makes alittle more boost. I have run 25 to 30 psi with a stock actuator and an RJC controller. You can make alot of boost by not sending boost to the actuator, then the boost will be will be limited by back pressure pushing open the puck.
