WOT in first and second boost holds between 25.5 to 26 psi. A/F hold's at 11.1. At the top of third boost has drop to 22.1 A/F is 10.9 at 5250 rpm's. Per the PL the boost slowly drops. Timing is 20* thru the whole run. 93/alky 42.5 inj. Eric's 5.7 chip. TA49 RJC fm 62mm tb Husek 9.5 3021 TC 2800-3000 stall. I have no knock. Car runs well. Would like to hear theories as to why the boost would drop. Also there are NO leaks, vacuum, headers or otherwise
