Syclone0044
Full Street Trim
- Apr 7, 2002
Hey guys, hope nobody minds if I ask here about my 91 GMC Syclone, I know tons of you guys run the same turbo in similar weight Turbo GM V6's :biggrin:
Old Stock Heads/Cam Results
When my truck was mostly stock with just a 2700 Yank lockup converter (700R4 trans), 93 octane & SMC dual nozzle alky kit (100% methanol), stock 28# injectors, and a little tuning, it ran a best of 11.8 @ 112 MPH around 23-25 PSI. I run a ball-and-spring manual controller from Boostvalve. The boost control looked like this (pink line). The red line peaks are 1-2nd, 2-3rd, TCC Lockup, and 3-4th:
Nice and flat, right?
New Stock Heads/Cam Results
Last fall I converted from the stock "swirl port" ~160cfm heads to late model Vortec truck heads that flow 227cfm intake, 171 exhaust. I also swapped from the stock 179/191* roller cam to a 218/218 115 LSA custom XFI roller cam. Obviously this greatly increased the flow of the engine. I quickly found what felt like the limit of my turbo at 16-20 PSI. I do all my own tuning with a wideband, laptop datalogger, and realtime chip emulator. I went to the track and made 6 passes, the fastest 2 were at the lowest boost (16-20) and the 4 runs I ran 21-22 PSI were the slowest runs. The slowest run was 11.65 @ 116.2 and the fastest was 11.45 @ 117.7.
I noticed the boost doesn't seem to maintain flat any longer. With the extra 800 RPM of the new heads & cam (4700 RPM redline before, now 5500 RPM), it seems like the turbo can't keep up? Here's what it looks like on my best run:
One thing I did was port the PTE turbine housing internal wastegate opening. I only opened it a bit and concentrated more on smoothing what used to be a 90* entry from the turbine. Is it possible the extra surface area is pushing the flapper open at redline?
Or is the turbo just tapped out? My truck is full street trim, full weight (3650# race weight with me in it). Could I have already maxed out the PT51 at only 11.45? I thought guys with heavy GN's could get this turbo into the 10s.
Race Videos
Here's a video of my best pass 1MB Windows WMV9, 640x480 High Resolution, 44kHz sound.
If that link doesn't work, here's the low-res YouTube version.
For complete detailed build info on the truck, see my webpage.
I also have more videos here.
Thanks in advance for your help!
Race Videos
